My phone felled in water and now it is showing a triangle warning ⚠️
What is the problem
What is the problem
Hi @michaelmone,
The phone has an IP68 waterproof rating but this was when it left the factory.
Check the status of the LDI (liquid damage indicator) in the phone to see if water has penetrated the case.
If the LDI indicates that water has entered then this may be the reason for the warning
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then disconnect the battery as soon as possible from the systemboard to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy S21 5G repair guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
could not of said it better myself
That’s hopelessly vague, any text to go with the warning?
Usually the phone detects liquid contact with pins in the charging port, clean and dry up the port first.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 55
