Shop the Holiday Gift Guide
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Are there any other batteries compatible besides the original?
I have an iPhone 2G that I decided to charge and turn on for the first time since I got it like 5 or 6 years ago. It worked fine then. Now it won't charge no matter how long I leave it plugged in. I've tried multiple cables in multiple outlets but it only shows the Apple logo for a few seconds before powering down when plugged in and it doesn't even show that if it's not plugged in.
Anyway, I suspect the battery's bad since it's been a long time since I charged it and it's rapidly approaching 20 years old anyway. But I can't seem to find a replacement anywhere. Every listing I come across is out of stock. I tried searching with the part no (616-0290) too.
I'm almost positive the cells themselves can't be replaced in this one, like you can in a laptop, so that just leaves substituting another battery. The original is a 3.7V lithium polymer with a positive and ground wire. There is no wire harness or ZIF connector like on most other batteries. I do not know if there is any microcontroller inside the battery or if all the charging tech is all on the main board.
I'm thinking some other battery made for another phone or media player may be compatible but I don't know what specs to look out for besides voltage and physical size. Or maybe that's really all there is to it?
Does anyone know what would make another battery compatible with an original iPhone?
Add a comment
1 Answer
Most Helpful Answer
Hi @newedge99
If you haven't already done so, try searching for 616-0291.
This is the model number of a compatible battery.
Some suppliers have them and some don't. It may depend on your location perhaps and how much you're willing to spend.
Here's the ifixit iPhone 1st Generation Battery Replacement guide that may help
Score 1
Add a comment
Add your answer
Talon Overstreet will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 13
Past 30 Days: 46
All Time: 345
