Replace, remove broken power adapter in power jack
Hello, what DC jack/charging replacement will I need?
Having a difficult time finding anything compatible with my model number.
1 Comment:
@qqrynmdkqxaprnl what is your model number? 2D629UA?
by
Add a comment
I do not think the power jack needs to be exactly the same model number. Usually a power jack that's compatible with similar model number laptops should work with yours. For example, I have an HP Pavilion all in one going under 24-b237c. However, components that are compatible with 24-b2xx (replace xx with another model) should work with mine.
Add a comment
Hi @qqrynmdkqxaprnl
Here's the maintenance and service guide, taken from this support webpage for the laptop model you selected.
Go to p.55 (65 of 104 pdf) to view the procedure to remove/replace the Power Connector cable.
The HP part number for the cable is L22528-001 (examples only)
Search online for the part number only to find other suppliers that may suit you better.
Add a comment
Add your answer
D M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 159
