Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2988 Questions View all
Battery iPhone 4s doesn't charge at all
Hi recently I open my iPhone 4S and now my battery doesn't charge instead of showing the lightning bolt icon indicating it was charging, it showed a plug icon. However, as indicated, the battery was continuing to run down so I tried all 3 cords, different outlets, etc. with the same result--the phone only showed a "plug" icon inside of the battery icon and the battery continued to lose charge. I tried turning the phone completely on and off but that only produced the same result. The battery inevitably lost all charge and my phone is now dead. Any suggestions?
Score 1
Comments:
I have the same thing with my iPhone 3GS i placet a new batery on it but it doesn't work.
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Most Helpful Answer
on the iPhone 4 check that the 2 tabs on the battery connector line up perfectly with the grooves on the phone. I missed this and my battery did not charge. When corrected all was good.
Score 1
Add a comment
My Iphone was not charging before I replaced the battery. No change after battery replacement. Now what?
Add a comment
there isn't much to mess up on a 4s. The battery plugs into the connector and get screwed down with 2 screws.
Take it apart again and make sure you have everything lined up. If it is, its possible that you got a bad battery.
Add a comment
Add your answer
Sergio Ruben Sanchez Balam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,424
