The current line of iPod touch comprises seven (7) different generations.
2619 Questions View all
Why doesn't my iPod charger USB work?
It used to work, but then there's been a lot of time i didn't go on the computer. I used to charge it on my iHome.
Score 1
1 Comment
Steffy, need some more information. What iPod version is it? Does it still get recognized by iTunes?
by
Add a comment
1 Answer
Chosen Solution
Steffy, try an AC adapter and see if it charges. It is possible that you battery is to run down to be charged through a USB port. If it charges on an AC adapter, you may need a new battery. Also, try a different USB port and a different USB cable. Check the dock connector for any corrosion, dirt and debris like pocket lint etc, check for broken and bend pins. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Steffy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,036
