Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Replaced full digitizer, now touch won't work.
I replaced the digitizer and screen together, as a combo. Now the screen will turn on but is unresponsive. I cannot unlock or anything. Ive reconnected the ribbons to the logic bored numerous times. any other advice?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Andrew K, if you double, no triple checked, your work and you are certain it is done right, there is a possibility that you received a faulty digitizer. Happens more often than people think. Contact your vendor and arrange for a replacement. Hope this helps, good luck.
Score 2
Comments:
Turns out after reinspecting it, it is a defective digitizer. already emailed the vendor and I'm hoping they don't drag their feet on this.
by
Add a comment
Add your answer
Andrew K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,382
