Lattissima Pro EN750MB - No water from Spout!?!
Had this machine for a number of years. Recently experienced the well-documented leaking from the Extraction Head. I replaced the Head ... produces espresso perfectly now/no leaking. However, now no water comes out of the water spout - so no hot water or frothing. All the hot water is diverted to the tray during this mode. I have tried all the "air pocket" removal techniques ... tried forced air back through the system and it comes out into the drain/tray area.
3 Comments
@oldturkey03 Sorry no. I supposed the solenoid valve, but they seem to work. Last chance: Opening the valve(s) and cleaning/descaling them. When OK, they make a clicking sound. Perhaps we should try a new one, they don't cost too much (about 20€), but you need a 120V version.
by VauWeh
MAJOR FRUSTRATION. I have had my machine apart no less than 20 times. I know it quite well. I replaced the solenoid, and it did not correct the issue. I have back-flushed water to bleed air from the system. Somehow in the last version of putting it back together, the button to turn on the water (on the top) is not working. The light turns on, but it does not turn on the water (so I cannot tell if it is even working now or not). It must be, through all of the rounds of taking it apart and putting it back together, that perhaps the plug from the control module to the PCB in the back has worn. I would love a schematic to trace it down. I'm not sure. Almost have given up.
by Chris Johnson
That is sad! I understand that very well, I myself have such a device in the garage and still haven't found the fault. Difficult appliances!
by VauWeh
