Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
Why is my battery draining in its sleep?
A few months ago I replaced my Mac battery with an ifixit mac battery because it was dying after only an hour or so despite its battery health in settings being “normal”.
Been extremely impressed with the improvement to overall battery life while using the laptop, however the battery will drain just as fast in sleep mode as if it were still on and being used. For example if I simply close the lid, do not shut it down and or do not leave it on charge over night, 9/10 the battery will be dead or at 1%-10% charge.
Is there any changes I should make to system settings after changing its battery? I’ve tried resetting SMC, turning off background settings such as screen time, location data etc. and other suggestions I found in the internet for this general problem experienced by Mac users.
Any suggestions will be appreciated!
Update (11/29/24)
Image 1 (battery 100%)
Image 2 (battery after 6 hours sleep)
Add a comment
1 Answer
This sounds like you have a running process which is stopping the system from going into sleep mode. Replacing the battery won’t directly affect going into sleep mode but that’s not to say there can’t be a power system issue either.
So let’s first deal with the power aspects, install this gem of an App CoconutBattery here we need to grab a few snapshots of the Apps main window. So with the battery fully charged take a snapshot with the charger disconnected, give it a few minutes to settle down first. Now put the system into sleep mode with nothing connected, give it at least six hours undisturbed. Bring the system back alive and now take another snapshot. Post both snaps here so we can see things.
Fixing a running process (or one that’s stuck) will require doing a hard shutdown, but before we do that let’s open up Activity Monitor and look at the running processes. Click on CPU and then click on %CPU column so the highest use is at the top. Take a snapshot down to the first 0.0 entries as you’ll want to compare this after you restart your system. I’ll be honest here this is a bit hit or miss.
2 Comments:
See coconut battery images as answer to my question. What now?
by
@alecgarner - Well you have something draining your battery for sure! There is a process draining your battery. Note the battery temps are way to high as the system is running hard! And even in sleep mode! Time to leverage Activity Monitor to see what is running. Focus in on the CPU column sorting on %. Let’s see what’s running. But we need to not have any Apps running for this test. Do a full shutdown and make sure you don’t have the check mark selected to restart or open anything. With the battery again fully charged monitor the processes which are running high. Post a snapshot here so we can see as well as it’s the odd ones we need to focus in on.
You may want to get the full version of TG Pro as it will allow you to see the thermals more clearly.
by
Add a comment
Add your answer
Alec Garner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 223
