Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Is difficult to separate Home Button from Flex Cable?
I have replaced 2 3GS screens and 3 iPhone 4 screens so I understand how to dissemble the phone. I have a red colored home button key that I would like to install.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The Home Button of the iPhone 3G/GS and iPhone 4, attach to their respective Flex Cables by simple double sided adhesive. So the Home Buttons can just carefully be peeled from the Flex Cable, if you like you can pry underneath carefully with a thin spudger. Then just line up and stick on the new Button to the Flex.
Comments:
Thank you very much sir
by
Add a comment
you can change the home button of iphone4 easily as compare to 3gs or 3gs. in iphone4 you just need to dismantle and remove the lcd from the phone. in 3gs you need a hot air gun to remove the touch from the bezel . thats why in iphone4 we can do it easily
Add a comment
Add your answer
Cody Ladison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 653
