Repair and disassembly information for Samsung's flagship S20+ Android smartphone, released in March of 2020.
Galaxy S20+ not charging via cable after the battery is fully drained
I’m experiencing a strange issue with my Galaxy S20 Plus. Everything on my phone works fine, except for charging via cable when the battery is completely drained.
When the battery reaches zero, the phone shows the charging symbol when I connect it to the cable, but the rotating circle doesn’t appear, and it won’t start charging. I’ve tried keeping it plugged in for an hour, but it still won’t charge. As a workaround, I tried charging the phone wirelessly. Once it reaches 1% charge and the green circle starts rotating on the screen, I can connect it to the cable, and it will begin charging normally.
I’ve also noticed that OTG does not detect any USB drives.
I tried replacing the charging connector along with the board, but this hasn’t resolved the issue. Could you help identify the exact problem?
Add a comment
1 Answer
Hello Nisam, Try using the original charger. Samsung has problems charging the batteries after they have been completely drained.
If you still have issues you may have to check the connections inside the phone.
If after all that you still have problems, You may have a faulty charging port or battery.
Happy iFixing!
Add a comment
Add your answer
Nisam Ponnani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 36
All Time: 470
