Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
579 Questions View all
Powers up to White screen, attempts to load twice, then shuts down?
After power up, it goes to White screen, displays rotating wheel and a status load bar... gets to 1/5th progress resets status load bar... again as far as 1/5th progress and shuts off! won't allow keyboard short cut commands pre white screen or on white screen... have followed online support suggestions re unplug power-mouse-peripherals etc.to no avail.
Any advice appreciated:
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
This can be a hard drive failure. I would try starting up from my original system installation disk. This failing, try disconnecting the hartd drive and starting from the DVD.
Score 3
Comments:
been busy.... done that... re-installed os, was working fine then repeated problem... done disk repair got the following...thru verbose..
iMac7,1 2007 SnowLeopard
Ran sudo /sbin/fsck -yf
acme back...
invalid key length
(4. 1882)
the volume MacHD could not be verified completely.
/dev/rddisk0s2 (hfs) EXITED WITH SIGNAL 8
by
Your hard drive has completely failed. Replace it. Here's how to do it: iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
by
Appreciate all assistance Mayer... have overcome previous difficulties and have the Mac back in action working well so far... it turned out that my original difficulty arose (these are my now educated opinions) when my Mac was attempting a 'faulty' firmware upgrade {I know this because I had restored my Mac 3 days ago and was working fine then I did an update and was thrown back to boot up difficulty and as described by my previous comment} resolved this with a 'virgin install' from disc...so now at the mo I will keep original firmware updates going and keep you posted periodically etc.
Now taking all that into consideration I would like to give a tit-bit of diagnostic of my original [problem] the non-functioning mouse/keyboard... many other user found similar difficulties with this (not just on this website but on the wider Mac fraternity) and after the usual recommendations fail to resolve the issue the popular advice was to take it in for [an expensive] Mac repair... MY ADVICE WOULD BE TO CHECK THOROUGHLY 'STICKY BUTTON' in other words make sure there are no keyboard keys in a depressed state as was on mine!!! this was compounding my frustrations initially... so a word of advice Mayer would be to include this as a part of user check list when encountering a Mac firmware/boot up issue.
Again I would like to thank you for you're support, it was reassuring and extremely important knowing I had a place to turn... who wasn't 'holding out their hand for 'payment first'... I think more companies and websites should remember that users are people and not all people have a job or disposable income to fritter....
Yours appreciatively,
John
by
John, probably 95% of the answers on iFixit are given by volunteers, not iFixit employees. Although I'm not completely uncompensated (I was given a tee shirt by iFixit about a year ago). I would think a sticking key would be something that would be noticed pretty quickly. If I were you, I'd still do a "write zeros" option reformat of your hard drive to eliminate any bad blocks and then do a re-install of the system.
by
Add a comment
John and mayer, I have the same symptoms. Although I bought the computer from a friend and I have no software available to me. What would you recommend I do. Thanks,
-eli
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,737
