The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Strange charging behavior with no amber led
I bought a MBA 11" as not tested, and it does not charge, or show any led on the charger. How ever, when i disconnected the interconnect cable to the I/O board and connected the charger, the charger lit up green. After i reconnecter the interconnect cable and plugged the charger back in, the green led lit up and faded shortly after. I checked the charger with my MBP 2015 13" and it works flawlessly. what could cause this behavior?
5 Comments:
1st step would be to install https://www.coconut-flavour.com/coconutb... and see what the battery status is.....
by
Are you using a MagSafe 1 to MagSafe 2 adapter?
Like this one? https://store.storeimages.cdn-apple.com/...
The MagSafe to MagSafe 2 Converter allows you to use the MagSafe connector on your LED Cinema Display, Thunderbolt Display, or MagSafe Power Adapter to charge your MagSafe 2-equipped Mac computer.
by
I am using a genuine Apple Magsafe 2 charger. The macbook is completly flat, so i can‘t imstall Coconut battery
by
@junkmaccol17375 - Did you replace the cable and I/O board?
by
I do not have those replacement parts on hand right now, but will order them soon
by
Add a comment
1 Answer
It sounds like either the cable or the board it’s self has a problem. Inspect both looking for damage, the cable or board might have damage within the connectors or there might be liquid damage. Here’s the guides for both and they both offer parts info as well
MacBook Air 11" Early 2015 I/O Board Image
Guide
MacBook Air 11" Early 2015 I/O Board Replacement
Difficulty:
Moderate
40 minutes - 2 hours
MacBook Air 11" Early 2015 I/O Board Cable Image
Guide
MacBook Air 11" Early 2015 I/O Board Cable Replacement
Difficulty:
Moderate
Add a comment
Add your answer
Junkmac_collector will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 124
