Model No. A1366 / 8 or 16 GB capacity
195 Questions View all
touchscreen doesn't work properly what to do?
I just got my nano and have my music downloaded. However, I can't get my touchscreen to scroll back to the main menu on it or any menu for that matter. What can I do to help solve this
problem? Right now I have to power it down. Help please.
Add a comment
1 Answer
Chosen Solution
brapot5, you can go ahead and check the cable on your iPod Nano. From what I read in your question, it does sound like your digitizer has failed. I would suggest that you change it. the part is available right here and the instructions for it are here. Of course make sure that you clean all the contacts and connectors with isopropyl alcohol and do look for corrosion on the connector. You could also try a restore through iTunes and see if the will make a difference. hope this helps, good luck.
Add a comment
Add your answer
brapot5 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,501
