Repair manuals and support for cars and trucks manufactured by Chevrolet.
762 Questions View all
2008 HHR right front half shaft inner knuckle replacement?
What specialized tools are required for the repair and repair proceedure?
Comments:
DouglasRJohnson, when you say the inner knuckle, what exactly are you referring to?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
DouglasRJohnson, this is going to be a very different answer. Mostly because I wanted to post an image so your could clarify which part you are referring to. To remove the wheel Drive Shaft replacement, you will need the tools :
J 45341 Rear Whhel Drive shaft Removal Tool
J-2619-A Slide Hammer
J 44394 Axle Seal Protector
For the inner joint and seal replacement you need
J 35910 Drive Axle Seal clamp pliers
Again, if you can be a bit more specific, I am sure I can get some more information.
Score 1
Add a comment
Add your answer
DouglasRJohnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 774
