Repair manuals and support for cars and trucks manufactured by Chevrolet, a division of General Motors.
1365 Questions View all
Question Closed
2008 HHR right front half shaft inner knuckle replacement?
What specialized tools are required for the repair and repair proceedure?
1 Comment
DouglasRJohnson, when you say the inner knuckle, what exactly are you referring to?
by
Add a comment
1 Answer
Chosen Solution
DouglasRJohnson, this is going to be a very different answer. Mostly because I wanted to post an image so your could clarify which part you are referring to. To remove the wheel Drive Shaft replacement, you will need the tools :
J 45341 Rear Whhel Drive shaft Removal Tool
J-2619-A Slide Hammer
J 44394 Axle Seal Protector
For the inner joint and seal replacement you need
J 35910 Drive Axle Seal clamp pliers
Again, if you can be a bit more specific, I am sure I can get some more information.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 839
