2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Question Closed
Horizontal Black/White lines, graphic card or screen problem?
It's a 2008 15" Macbook Pro with a Nvidia 8600M GT, and a C2D 2,4ghz.
http://i.imgur.com/R8L2l.jpg
Thanks in advance!
Add a comment
Chosen Solution
After you check it with an external monitor, if the external shows the same problems, call Apple for a free logic board replacement for the Nvidia 8600 GPU issue. You may still be within the 4 year limit Apple set on this or be able to get an exception because it is so close. Here's Apples notice on this along with where and how to contact them: http://support.apple.com/kb/TS2377
Score 3
1 Comment:
+ Helpful information about the extended warranty coverage.
by
Add a comment
Connect to an external monitor if the lines are missing from there it' might be the controller board for the LCD. I'd replace the entire display as futzing with the controller board alone is a lot of delicate work...Once you get the back off the display you can find the right part number for the screen.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 7,259
