Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
406 Questions View all
Is it possible to replace the audio out jack?
A few days ago I use a headphone do listen to music on my macbook pro but the headphone I was using was a bit old so the end of the pin it was a bit lager than the normal and now the other headphones I have (newer ones) stay too loose when plugged and disconnect very easily.
Do you think it is possible to replace the audio out port? And do you think Apple would do that without charging me (I'm still covered by the warranty)?
Thanks everyone for your attention.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If your system is still covered by AppleCare I would bring it in ASAP. I wouldn't get into details how it got damaged.
The audio jack is soldered onto the main logic bd. and would be very costly if you have to get it replaced out of warranty.
Lastly, I would replace the plug on that older headphone set (if they are worth saving) so you don't damage the outlet again (as well for any other cords).
Add a comment
Add your answer
Felipe Moran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,873
