Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
3046 Questions View all
small part dropped out during repair, where does it go?
Hi, I recently tried to install a new screen in my iphone and during re-assembly a small gold clip about 5mm long
dropped out, I have looked at all the 4s exploded views I can find and that part is never there. Also now flash sin't working on camera and nor is wifi, anyone got any ideas why this is so? Any help would be greatly appreciated, as I now have a £500 phone in bits on my desk. :-(
Score 3
Add a comment
Chosen Solution
Is it this?
Also, any idea on the black rubber part?
Score 4
Comments:
Hi I can confirm the little black rubber bit sits at the top of the logic board and protects the display cable from damage. Thanks for the info but I'm not sure if that's the right part, it does look similar I'll upload a pic of it tomorrow.
by
Hello again look thanks man that IS the part, not sure if it will fix problem with the flash but i hope it does, TOP MAN!
by
thank you so much!!! i had this left over too :) :) :)
by
Add a comment
it's probably the where the camera mounts. without pictures, i can't know for sure. i recommend following the guide to replace the lcd screen for the phone. it'll show step by step instructions and you'll eventually come across that part in the walk-through.
Update
iPhone 4S Screen Replacement
Step 16, enlarge the picture where the person has the camera in his finger tips. Look where the camera was and you'll notice the piece you're missing. It's normally underneath the black sticker on your logic board where the camera sits. The location of the black rubber piece is a problem I've been having also. I'm almost certain it was on the logic board by the display ribbon connector, the top edge, but i'm not certain. I'll let you know if I figure it out. Please do the same if you find out.
Update
Step 23 also shows the gold clip as well. That screw he takes out holds that gold clip in.
Update
Step 25 also shows a very clear picture. Enlarge the picture to the max and you'll see it at the bottom right.
Update
lol, step 26 pretty much sums up everything...
Score 2
Add a comment
Yes the gold piece is the camera ground clip and is held in place with a screw on the upper left of the circuit board. The black piece is a protector that is on the upper left/top of the circuit board for the Screen connection ribbons to bend over and connect to the circuit board.
Score 2
Add a comment
The gold piece is the camera ground. It belongs under the motherboard corner screw closest to the camera. The "prongs" should be against the top of the case and the screw covered with the black "tape". Hope this helps.
Add a comment
Add your answer
Oscar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 37,542
