Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
683 Questions View all
Hard drive is making a clicking noise
Lately my iMac's HD has been making a "clicking" noise intermittently - is it on the verge of failing? When the issue begins my iMac freezes until the noise stops. I've ran several SMART tests with a 100% pass rate.
Should I replace it before it fails? Or is there anything else I can do to diagnose and/or fix the issue?
Score -1
Add a comment
Chosen Solution
Sounds like a bad hard drive to me. Your machine is under warranty so take it in ASAP after you have backed up your data.
Score 2
Add a comment
Hi David,
  • Your hard drive is producing clicking sound, this might be due to any physical damage received.
  • Take the data back up immediately, either image it or clone the drive.
  • But, if your drive is inaccessible then run a Mac data recovery software to get back your files. You can download a data recovery Mac software to do this - http://www.stellarinfo.com/mac-data-reco...
  • Avoid any further experiment or diagnosis of your drive until and unless you are expertise enough to do so.
Score 1
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,831
