I'm trying to take the door panel off to replace a speaker
Can you tell me how to remove the arm rest so I can get the door panel off ?
Here is what the manual has to say:
FRONT DOOR FINISHER
Removal
1. Remove step lamp lens and disconnect step lamp.
2. Remove screw cover and pull cup mat.
3. Remove screws.
4. Remove and disconnect power window and door lock/unlock switch.
Remove screw beneath power window and door lock/unlock switch.
5. Remove upper cover from door finisher.
6. Remove front door finisher.
Installation
Installation is in the reverse order of removal
The attached image should help to find the screws that hold it on. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,736
