Released March 2017, model number 20JS0004US.
Battery Issues - Stays @ 5% while plugged in, will not charge.
Hi everyone! My dad gave me a thinkpad a few months ago. it is a T470s model, product number 20JTS1FQ02. It will not charge anymore, and the battery level remains at 5%. This all happened shortly after a windows update, but I'm not sure the two are related.
I have an update available for the BIOS and the Intel Engine Management Firmware, however I cannot apply said updates until the battery has a minimum charge of 25%. I pulled the rear panel out, disconnected both batteries for about 30s, and then put them back in after pressing the "emergency" button on the back for about 15s. Do the batteries need to be installed for that button to do anything?
If my batteries are shot, I can replace them. I see on the site here there is a genuine replacement LiPo for the rear battery, but I can't seem to find the front one. I found one that works on the T460, but I can't verify its compatability with the T470s. Looks to be the same but I'd rather not buy it and be stuck with it if it does not work.
Any help would be appreciated, I need this laptop to work for my classes.
Thanks!
Add a comment
1 Answer
Two things to try
  • Calibrating the Battery
The Lenovo OneKey optimizer may help:
Click below, download and install
OneKey Optimiser for Window
I guess this doesn't apply to you but others may find the note below helpful:
Note: Manually calibrate the battery by charging the battery to 100%. Allow the battery to drain down to 5% before charging again.
  • Generating a Battery Report in Windows 10
1. Right-click on the Start menu to bring up the menu
2. Command Prompt
Choose Command Prompt (Administrator) from the menu. Note that this must be the Admin version and not a regular command prompt.
3. Yes to UAC prompt
A prompt will appear to which you need to give permission
4. Command
Copy and paste powercfg /batteryreport /output "C:\battery_report.html" into the command prompt window. Note that for the pros you can designate the output to any directory. For simplicity, we are placing it in the C:\ root folder.
5. Open file
Using Explorer navigate to C:\ aka the root directory. You should see a file labeled battery_report.html. Double-click on it to open the file in your default browser e.g. Firefox, Microsoft Edge, Chrome, Opera
Let us know how it goes.
Add a comment
Add your answer
Dan the Man will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 605
