Repair and disassembly information for Samsung's S22 smartphone, released in February 2022.
Replaced the charging port and now it will not power on
I replaced the charging port, when I plug the charger in the screen shows charging but will not power on. I have rechecked all connections and even put the old one back in. Still nothing.
Add a comment
1 Answer
Most Helpful Answer
I'm wondering if by chance you bumped the power button connector loose from the motherboard. If that's not plugged in securely, the motherboard may not be getting the button press. The Spanish site Nadie Me Llama Gallina has a guide for replacing the buttons, and it shows exactly which connector goes to them.
Manuals / Samsung Galaxy S22 / Side buttons - Nobody Calls Me Chicken
Here's an image from their guide showing the connector to check.
Other than that, you'll want to retrace all of your repair steps and check the connectors you did disconnect. Unplug them and check them with a magnifying glass looking for bent or broken pins. If it all looks good, clean both sides of the connectors with 90% or higher concentration isopropyl (rubbing) alcohol, give it a minute to dry then plug it all back in and recheck.
Let us know what you find and we'll see if we can figure out what to do next.
Update (07/05/26)
Unfortunately, the Nadie Me Llama Gallina site appears to have been taken over and taken down, so the previous link to their repair guide is no longer usable.
Score 1
Add a comment
Add your answer
Christy will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 24
All Time: 303
