The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Questions View all
Question Closed
only kids wear and hand wash wool work, why?
kenmore Elite washing machine---
kids wear and hand wash and wool are the only two cycles that work, why
Add a comment
1 Answer
Chosen Solution
Selector switch
If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly
Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 441
