Shop the Holiday Gift Guide
TV led blinks red and green. Screen on but nothing shown
Hi. The led of my Toshiba 50ul2063db is red when in stand by but when I turn the tv on it flashes green and red for 4 times. I can see the screen kind of turning on but nothing is shown on it. Isn't connected to anything yet (no hdmi, no vga or so) but on the screen not even the NO SIGNAL text is visible. After few minutes (2, probably) the tv goes back to stand by mode. I have used a flashlight to see if I can see anything from the TV (to check if it can be the a faulty led strip) but I cannot see anything. I opened the back of the TV but I don't see anything that can be blown up. Is there anything that I might change (the t con board, maybe?). Let me know your thoughts! Thanks to anyone will answer me
2 Comments:
@matteofelicione remove the back cover once more and take some really good (well focused ) pictures of all of your boards. Post those with your Question. That way we can see what you see.
Your TV should have a hodge podge of boards and one of those should be the Vestel main board. Those are flaky boards. Toshiba is a horrible company that does not support any self repair and manuals/schematics are hard to come by. Toshiba uses their hordes of attorneys to intimadate repairers etc. So, this will be a difficult fix but not impossible. Once thing we need to see clearly is the connector on the power board, where the main board connects to. Let's see if there is an err detect connection. If so, we can possibly bypass the blink code. BTW Toshiba is even vague on those. You will need at minimum a multimeter. Adding images to an existing question
by Share
Hi. I modified the post, adding some pictures. I cannot open the panel where the tcon board is due to two stripped screws that don't allow me to do it. The only way would be destroy the screws or cutting part of the panel with a dremel (I might choice the second way). Let me know if you see anything wrong and thanks for your answer and help.
by Share
Add a comment
The flashing is an error code look up the manual or repair manual online and it should tell you what they mean exactly and which board is at fault.
Not sure if T.V’s are covered here I think they are though.
https://www.google.co.uk/search?q=toshib...
4 Comments:
Thanks for your answer! The blinking led stops blinking and set to the green light after 4 blinks. The manual doesn't mention this behaviour anywhere. On the troubleshooting section there's no trace of this issue. The only mention on the manuals is "Note: When the TV is switched into standby mode, the standby
LED can blink to indicate that features such as Standby Mode
Search, Over Air Download or Timer is active. The LED can
also blink when you switch on the TV from standby mode".
I haven't connected the TV to any sources yet but I was expecting to see something on the screen. Can you confirm this?
by Share
It looks like it’s a power-board issue. It’s possible it’s firmware related I doubt it though but I could be wrong. I can’t find the error codes I had a link but lost it . https://www.smarthomebit.com/toshiba-tv-...
by Share
You could try asking your question here also https://www.badcaps.net/
There are people who do Toshiba flashing and all sorts you might get more specific info than I can give you or even a firmware fix possibly.
by Share
Thanks so much for your help and comments. I will forward this question to the website you mentioned. Thank you very much for your help and support
by Share
Add a comment
Can i replace a my vga input with a hdmi input on my monitor
Add a comment
Add your answer
Matteo Felicione will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 622
