Shop the Holiday Gift Guide
A portable bluetooth speaker that was first released by Bose in 2021.
Can I fix my charging port if the metal part fell off and won’t charge
My charging port fell out the charger hole and before and now the device won’t charge
Add a comment
1 Answer
Chosen Solution
Hi Alexander,
It looks like you're not alone in having this happen; while researching I saw quite a few people with the same problem.
The port itself can indeed be replaced, but the bad news is that it's not an easy repair. The biggest issue is the fact that it's a USB-C port, which has a lot of pins. That in itself isn't necessarily a scary thing, but this connector has two rows of pins, one that is completely hidden underneath the other row, meaning the part cannot be soldered onto the board with a soldering iron; a hot air station must be used in order to replace the port. That assumes that the traces on the circuit board haven't been damaged by the port coming off; if they have that complicates the repair by an order of magnitude.
Anyway, if this was something you wanted to tackle anyway, the first thing to do is to pull the motherboard from the device so you can access the charging port. I changed the device page your question is posted to; as it turns out there were two Bose Soundlink Flex pages and the one you linked to was only a stub, while the other one has guides, one of which is exactly what you're looking for.
Bose Soundlink Flex Charging Port Replacement - iFixit Repair Guide
As far as buying a replacement port, they seem to be fairly readily available online; here's one from AliExpress that is showing two connectors; you'll have to physically examine yours to see which one you need.
1PCS Type c Jack USB C Type-C Power Dock Charging Port For Bose SoundLink Flex micro Laptop Connector Socket Repair - AliExpress 13
Of course, if the soldering is out of your comfort zone, you can always try contacting a local repair shop to see if it's something they would do; you might even be able to save a few bucks if you pull the board yourself and provide the replacement connector. For most experienced technicians this should be a fairly straightforward job with the proper equipment.
Score 2
Add a comment
Add your answer
Alexander Leal will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 108
All Time: 1,715
