1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
SSD, either instead of optical drive or as second SATA device
hi there,
my optical drive was not really working from the beginning, so getting rid of it would be a good idea. the optimal solution would be to insert a SSD instead of the dvd-drive.
reading this discussion(SSD instead of optical drive), i'm wondering if the same is valid for my older macbook pro / A1150(2006 model). the hdd is SATA, but according to the system profiler, the MATSHITADVD-R UJ-857 optical drive is an ATA device, so that's a completly different kind of interface.
so i guess the only option for using a SSD would be to replace my current 100GB sata with an sata-SSD. or perhaps there is a second SATA interface onboard?
thx & so long
harri
Score -1
Add a comment
1 Answer
Chosen Solution
There are optical bay adapters now for using either SATA drives or PATA (ATA, IDE, EIDE) drives in your older MBP or even in PowerBooks. I just put an SATA in a PowerBook this week. I really like the LaCie external optical drives as they are very durable and priced well under an internal drive.
http://www.lacie.com/us/products/range.h...
Do a web sear for "mac & optical bay adapter".
Score 2
1 Comment:
THX for your response!
maybe that was a little bit unclear, but i really don't need an optical drive.
do you know how this adapter performs? because it would be nonsense to put an SSD into this adapter to get a performance-benefit, but to introduce a new bottleneck(the ATA-SATA - converter).
any idea if there is a second SATA-controller onboard?
so long,
harri
by
Add a comment
Add your answer
hagl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 533
