The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
Why can't put the key in the switch to start my car
Small stick stuck in the car switch and can't put the key in to start the car anymore,
Add a comment
1 Answer
If there are still pieces in there and the key is pushing the debris and pin tumblers down the barrel won't turn. The stick may have lost pieces that are still in the ignition, remove them. As I'm sure you removed the stick your helpful tyke placed in there if there are pieces in there you may be able to blow/vacuum them out. Use a duster or something similar.
Add a comment
Add your answer
Maysa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 167
