Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3248 Questions View all
Water Damaged iPhone won't power on
I am working on an iPhone 4 and a little confused. The phone got slightly wet and shut down yesterday. Since it has not powered. I replaced the battery and dock port with same results but if I take the logic board and put it into known good phone it powers right up. What would be my next step here?
Add a comment
Chosen Solution
wurmy1, my suggestion is that you clean your iPhone before any corrosion will further damage your phone. Use this guide to accomplish that. It was written for a 3G but applies to your phone as well. When you transfer your logic board to another phone, and it powers up, take a look at what parts you do not transfer. Since it works in another phone, the part that does not get transferred is the culprit.
Score 2
Add a comment
Most Helpful Answer
Take the phone apart and set the parts in dry rice over-night. It should absorb the rest of the moisture that is left in the phone. Then try putting the phone back together and see if that helps.
Score 2
Add a comment
Add your answer
wurmy1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 492
