The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
Mengapa ketika habis dijalankan, ketika masuk ke D ga bisa jalan
Mengapa ketika mobil panas atau habis dijalankan ketika masuk ke D mobilnya ga mau jalan,harus di gas tinggi baru bisa jalan dan gak mau pindah gigi.. Chevrolet Cruze 2010 matic
Why is it that when it's finished running, when it enters D it can't run? Why is it that when the car is hot or finished running, when you enter D, the car doesn't want to start, you have to put it on high gas before it can start and it doesn't want to shift gears... 2010 Chevrolet Cruze automatic
1 Comment:
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Hai Begitu banyak hal yang perlu diperiksa Pembersih udara, air, oli, bahan bakar, waktu, busi, oli transmisi dan banyak lagi. Cara terbaik adalah dengan menghubungkan pembaca OBD ke komputer dan melihat kode kesalahan apa yang dimiliki sistem kendaraan. Anda mungkin perlu menemukan seseorang yang memiliki salah satu dari ini atau membawa ke bengkel dan Membayar untuk memeriksa. Semoga ini membantu
Hi,
So many things to check
Air cleaner, water, oil, fuel, timing, spark plugs transmission oil and more.
The best way is to connect OBD reader to computer and see what error codes vehicle system has.
You may need to find someone who has one of these or take to repair shop and Pay for checking.
Hope this helps
Add a comment
Add your answer
Ferry Supriyadi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 143
