The Raspberry Pi 4 is a versatile single-board computer developed by the Raspberry Pi Foundation and is the fourth iteration of the Raspberry Pi line of products.
Shows color screen than looks like disconnected from screen
I have my raspberry pi 4 plugged into a Anker surge protector (same thing happens without the surge protector) with this old Acer monitor that I had around, when it boots it will get to the color screen than disconnect, the monitor says no signal, raspberry pi worked on a TV but refuses to work with the monitor. I plugged an old Roku Stick into the monitor and it works. Any idea why my raspberry pi doesn't work with the monitor? Model number for the monitor is S231HL
Add a comment
1 Answer
Chosen Solution
The Raspberry Pi video driver logics scan rate is different than what the Monitor can support. You may need to alter the monitor’s settings matching what the Raspberry PI is able to support if that is possible.
1 Comment:
I will try thanks
by
Add a comment
Add your answer
CinnamonCat1001 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 268
