Why is my phone showing off radio mode before I can make calls or use
I can't make calls or access internet with mobile data only wifi it's shows radio mode on
If your phone is showing "Radio Off" mode before you can make calls or use mobile data, it means that the phone’s cellular radio is turned off or disabled. Here are some possible reasons and solutions:
1. Airplane Mode is On: When Airplane Mode is enabled, it disables all cellular, Wi-Fi, and Bluetooth connections, causing the phone's radio to turn off.
- Solution: Check if Airplane Mode is enabled and turn it off from the quick settings or in the settings menu.
2. Network Settings Issue: Your phone’s network settings may be incorrectly configured, preventing the cellular radio from working.
- Solution: Go to Settings > Network & Internet > Mobile Network, and try resetting or re-enabling mobile data and network settings. You can also try resetting all network settings.
3. SIM Card Problem: If the SIM card is not inserted correctly or there’s a problem with the SIM, the phone may show "Radio Off."
- Solution: Try reinserting the SIM card or testing it in another device to see if it’s working properly. If the problem persists, contact your carrier for a replacement SIM.
4. Software Glitch: A software bug might cause the radio to be turned off unexpectedly.
- Solution: Restart your phone or check for software updates to resolve any glitches.
5. Hardware Issue: In rare cases, the phone’s radio hardware might be malfunctioning.
- Solution: If the issue persists despite trying all other solutions, it may require professional repair.
If the problem continues, contacting your mobile carrier or the phone manufacturer might be necessary for further troubleshooting.
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 198
All Time: 1,173
