The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
What is the correct stm32 microcontroller for the Flipper Zero?
The Flipper Zero uses the stm32 microcontroller but STI, that makes the board has so many choices. Can you thin out the choices?
Score 1
Add a comment
1 Answer
Chosen Solution
Hi David,
Have you opened up the case? The chip itself should have sufficient information marked on it to be able to identify the correct replacement part to order.
Can you take a picture of the chip for us and add it to your question? We have some folks on here who are really good at looking this sort of thing up if you can.
Adding images to an existing question - iFixit Repair Guide
Score 1
Add a comment
Add your answer
David Bourland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 112
