Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Screen has a grey stripe
I replaced the home button and after I put all the pieces together the screen has a stipe going up and down the screen works but I can use it I just can't see
How do I fix it ?
Add a comment
1 Answer
Chosen Solution
Hi Dulce,
A grey stripe on a screen is the result that some lines (depending on the width of the stripe) are not powered any more.
This might be caused (examples):
a) through a connector that must rest flat but which is actually not
b) through a spot at the frame of the screen where the conductor path was lifted or got loose (e.g. through a tiny piece of anything or - accidently through pulling too strong on the ribbon cable of the connector)
I suggest you open the iPhone again and check all connections, especially the connector of the LCD (see the manual for the iPhone 4, step 17; the connector marked by the orange rectangle).
Also, depending on the width of the stripe, I would check the affected top and bottom area of the LCD frame.
If anything doesn't work, I would suggest to buy a new LCD/digitizer unit and to replace the old one.
Steffen
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,330
