This Power Mac G4 has Mirrored Drive Doors.
80 Questions View all
Question Closed
I have a problem whit Mac os x 10.4 install.
Before finishing the installation it throws a message that he says that I provoke a problem during the installation. I did reset to the NVRAM, alone after-taste the memory RAM of factory, made it run in sure way and throw a mistake like this: RELEASE_PPC, i remove the RAM that is not of factory and now it throws a mistake of installation that says something as:
BootFatalError-cpio read error: bad file format
Install failed: algunos archivos de essentials pueden no estar bien escritos
thank you for the help. Ronny.
Add a comment
Chosen Solution
The cpio is usually found with UNIX. Are you trying to install 10.6?
Score 3
Add a comment
I try not even to another system disk, to check that I have in the install no problem, it may be the disc? may be the battery of logic board?, reset PMU have not, thanks for your help
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 541
