The HP 255 G8 Notebook (Model: 7N4W2AA) is a 15.6-inch budget-friendly business laptop, typically powered by an AMD Ryzen 5 processor. Based on search results, this specific variant usually features 8 GB of RAM, a 256 GB SSD, and Windows 11 Home, targeting everyday personal or business use.
It turn on time showing “no bootable devices found”
It turn on time showing "no bootable devices found"
Add a comment
1 Answer
@rashdhan this is most commonly caused by a failed HDD or SSD depending on what your computer has. You could try to enter the BIOS of your computer on startup and see if the drive still shows in the BIOS. To work on your computer use the HP 255 G8 Maintenance And Servcie Guide to work on your HDD or SSD. You most likely will have to replace the HDD and reinstall your OS. The manual will also help you with this.
Add a comment
Add your answer
rashdhan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 130
