Troubleshoot and repair your music players from the early 2000s.
6925 Questions View all
Why does my Panasonic RX-DT55 cd player stop mid-track?
I have a Panasonic RX-DT55 Portable Stereo CD System. The CDs play but stop randomly as if running out of steam. Can I repair this (or bring it somewhere - I live in Finland), or must I throw it away? The model is about 17 years old, and served me well so far.
Add a comment
1 Answer
Chosen Solution
Reni, it is possible that this caused by a mechanical failure or your CD servo. You may have to take the unit apart and take a look. Once apart, take a look at the spindle motor and clean all the part. the spindle motor would be the most likely reason for the "running out of steam". With a unit that has that many years of good service, sometimes a good cleaning is all that is needed. It all depends on how handy you are as well, since there are a few mosfets ad power transistors that can be at fault. For the CD playback they are IC701-IC705 that may give you issues as well as R701:-) You should find those numbers on the PCB. Hope this helps to at least get you started. Good Luck.
Score 1
Add a comment
Add your answer
Reni will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 622
