Troubleshoot and repair your music player.
7530 Questions View all
Why doesn't my Panasonic RX-D29 CD-Player recognise most CDs?
Some CD's are recognized by the player and play o.k., some are not recognized and won't play. What do I do? The machine is about 7 years old (compact radio/cd/tape player).
Must I buy a new one?
Add a comment
1 Answer
Chosen Solution
Reni, at first make sure that your files are in the right format, also make sure that if you are using burnt CD's that you use the brand which your player recognizes. Sometimes it works if you slow the burn speed down. If you are trying to play a CD that contains MP3 format data and normal audio data (CD-DA), output from one of those may become silent, and play may not be possible. If this happens with commercial disks, the once that you buy,as well, I would suggest to clean the laser assembly of your player. For that you could try a CD lens cleaner. Most department stores should have those available, of course that depends on where you live. If you can not get it, you may have to disassemble your player and clean the lens assembly with some high grade isopropyl alcohol. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Reni will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 675
