Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
Phone will not power on or be recognized on computer. Fix?
So I have an iPhone 4 that will not power on or be recognized in a computer. I removed the battery and plugged the phone up, but no response. I ordered and replaced the dock connector. but still didn't get a response. Does it have a bad logic board or is there something else that I can try?
Add a comment
Chosen Solution
Replace the battery. If that does not help, it's probably the logic boarfd.
Add a comment
Hi Curtis
Have a read of this post
Will not power on, what could it be?
This post I believe gives you good recommendations to start of. Also have a look at the logic board and see if you can notice any corrosion, if so do a isopropyl alcohol solution bath to help loosen the corrosion and using a soft bristle brush like a soft toothbrush lightly brush the corrosion off. The alcohol bath will also help remove any kind of moisture that may be on the logice board.
Add a comment
Add your answer
Curtis Austin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 498
