Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3231 Questions View all
Do I need to replace partially torn audio jack cable (interior)?
While doing a combo power and sensor cable/dock connector repair (I tore the dock connector completely while peeling it back) I noticed a small half-tear to the black cable attached to the audio jack that connects to the logic board. Will this function in its current state or do I need to replace it?
Here's the picture- http://i1015.photobucket.com/albums/af27...
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Tom, I would suggest that you fix what is broken. I would honestly not expect it to work if it does not get replaced/repaired. Broken, even partially broken, parts usually cause you more trouble later on. Replace it now and be done with it. :-) Just my 2 cents, good luck
Score 1
Comments:
Thanks for the advice. Also, do you think you could take a look at this question? I'm having trouble with the front-facing camera. iPhone Front camera won't fit into place..
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 318
