The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
647 Questions View all
yellow light fix did not work?
just disassembled ps3 did re solder as kit said.now when i plug in ps3 green light comes on,it makes 2 beeping sounds than turns red again.double checked all ribbon connectors. any idea's?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
jamesleising, so you did the reflow. You must use a heat source that is adequate. Most errors made with this is that a. not enough heat was used b. heat is not applied long enough for the solder to properly liquify to reflow. I would suggest that you repeat the process and check the time to reflow your board. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
jamesleising will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 492
