yellow light fix did not work?
just disassembled ps3 did re solder as kit said.now when i plug in ps3 green light comes on,it makes 2 beeping sounds than turns red again.double checked all ribbon connectors. any idea's?
jamesleising, so you did the reflow. You must use a heat source that is adequate. Most errors made with this is that a. not enough heat was used b. heat is not applied long enough for the solder to properly liquify to reflow. I would suggest that you repeat the process and check the time to reflow your board. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 506
