Rpm is not istable.it is up and down specialy if the ac is working
Why my accent 2015 model is the RPM unstable. Up and down.specialy if ny ac is working?
Score 1
4 Comments
My RPM is too high and the care consumes alot of fuel
by
@fatihkasozi Faith, you'll have much better luck starting your own question. Assuming you also have a Hyundai Accent SE, please include the year, transmission and engine information and what you've done so far to try and figure out the problem.
https://www.ifixit.com/Answers/Ask/Hyund...
by
It's a Hyundai Accent 2012 model engine capacity is 1.6 I have tried changing the coils but it's not working the RPM is too high when ever I start the car and sometimes even when IAM driving and it dose this even when the AC is off
by
Same issue I had
by
Add a comment
Chosen Solution
The rpms will fluctuate especially with the A/C is on because the compressor kicks in and out which throws extra load on the engine and the frees up the load when it kicks out. The coolant radiator fans can also cause this by putting extra load on your alternator, all this being said the fluctuation should be minimal!
Score 3
1 Comment:
I would like to point out that although this is good information, it doesn't actually cover the original question fully, as the poster specifically said the RPMs are unstable with the A/C off, but is worse with A/C on. The answer here doesn't account for what's going on when the air conditioning is not on.
by
Add a comment
So what is the posible damage.
Add a comment
Add your answer
Khalid will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 56
All Time: 438
