Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
How to replace the power IC, iPhone 3GS logic board?
So I posted awhile back about a 3gs I had got a hold of that did not seem to power on no matter what I do. I've already went through the standard trouble shooting. I've replaced the dock, and the battery. More recently another 3gs I got a hold of with a good logic board that works with the same combination of new parts that I've put together...
Now that being said its definitely the logic board. I also tried putting the bad logic board in another phone and it didn't work in there either. I'm having issues finding a good walk through for a power IC replacement or another means of troubleshooting that I can perform to diagnose what the issue is with the logic board itself. If anyone could point me in the right direction it would be much appreciated!
In addition I do have a multi-meter, but I can't seem to find any diagrams as to what I should be testing on the board or what kind of read outs I'm supposed to expect from it to determine whats working and whats not.
Thanks in advance!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Cobaltthegreat start of with measuring the circuit as attached to this answer. The reason why you have a hard time finding instructions on replacing the power IC, is because it is not an easy thing to do. The only instructions I have seen (and definitely saved) are here. Again, hope you have some experience and good tools, as well as great eyesight :-) Hope this helps, good luck.
Score 1
Comments:
Thanks sir! I have some soldering experience but that's about it. The broken logic board was a freebie so I figured it would be a good place to start tinkering. Nothing to lose! :) I'll let you know what I find out.
by
Sounds good, try to use hot air or IR soldering. Let us know how it is working out.
by
Add a comment
Add your answer
Cobaltthegreat will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 9,610
