Shop the Holiday Gift Guide
The Meta Quest Pro is a Virtual Reality system that was released on October 25th, 2022. It was Meta's first headset to feature pancake optics.
Do Quest Pro controllers use the same joystick part as Quest 2?
Hi, I hope someone who has experience disassembling or repairing Quest Pro and Quest 2 / 3 controllers can answer this.
I've heard that Quest 2 and 3 controllers use an identical part for their analogue sticks, but can't find any info on QPro controllers.
This is important because Quest 2 replacement sticks are currently available from Amazon and elsewhere, but there's nothing labeled for Q3 and QPro as far as I know.
Thanks
Edit: Replacements labeled for Q3 are now available.
I also found this reddit thread:
https://www.reddit.com/r/oculus/comments...
"Posting a year later for others looking for confirmation.
The quest 2 thumbstick component is compatible with the pro touch controller, go ahead and replace with quest 2 part.
However, the capacitive spring that is inside of the thumbsticks are not compatible - take care not to deform or stretch the pro controller spring when disassembling the controller to replace the stick assembly.
Good luck, its a complicated teardown."
Score 1
Add a comment
1 Answer
Chosen Solution
Score 1
Add a comment
Add your answer
Jeff will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 118
All Time: 2,512
