The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
14 Questions View all
Can the motherboards be swapped out?
My phone screen stopped working the blacklight turns on and I had it repaired and they said it's a problem with the motherboard and not the LCD ribbon. So my question is can the motherboard be swapped for a new one?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If you're asking if you can replace the motherboard from your Droid 2 with another Droid 2 motherboard, the answer is yes. The only thing you'll have to keep in mind is that anything you had saved to your phone's internal memory will be gone. If you're asking if you can take the motherboard from a different model of Droid, the answer is unfortunately no.
Comments:
yeah i was asking about swapping a droid 2 motherboard with another droid 2 motherboard, thank you for your answer!
by
Add a comment
Where can i buy a Motorola droid 2 global mother board?
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 704
