How can I clean inner keyboard under upper cover?
I spilt coffee with LOTS of sugar. It's a premade coffee milk drink.
Currently my computer turns on, but I cannot type my login and password since the keys A to L does not work. Caps lock and semi colon work. I'm assuming this row's keys circuit is damaged somewhere.
*I've opened top case or upper case and cleaned with alcohol and cotton ear swab.
I've also
*I've also taken out each key, cleaned a lot of stickiness and put it back in successfully.
Nothing has worked. I took to local shops here in Japan and they said it will cost me flat rate of about $800 to investigate and fix liquid spills for macs :(
What else could I do?
Is there a photo of a what an inside of a perfectly working inside looks like that I can compare to???
Thanks
1 Comment
Please, provide us with the last four letters and numbers of your serial number. You can access it from System Profiler, once you boot with an external keyboard, or on the box of your laptop.
by Stefano Gigante
