The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
My car engine RPM is fluctuating
Add a comment
1 Answer
Greetings Dillip,
The first thing I would do is check for vacuum line leaks and do a Throttle Body Adaptation.
  1. Disconnect battery for 30 mins.
  2. Reconnect
  3. Turn key to on for 15 secs ( You will hear clicking as the adaptation is going on ).
Start engine
If it doesn't improve, check again for vacuum leaks. - If no vacuum leaks can be found. Scan the car with an OBD scanner and check the O2 sensor.
Report back with the results and let me know.
Cheers!!
Moe
Add a comment
Add your answer
DILLIP GADANAYAK will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 130
