Why is the iPod touch not sliding after full repair?
hey guys. i was trying to fix my iPod touch 4g last night and the screen completey shattered. and i bought the 4g screen replacement lcd thingie and the problem is when i too out all the screws and re hooked up the lcd wire, and the black wifi ribbon cable wire that wrapped around the bronze aluminum foil and rescrewed in all the screws then properly placed the lcd wire. the screen worked right don't get wrong but my question is why did it slide?
1.why didn't my screen slide after connecting all the wires back
2. how to pry the screen back in? i don't want to break anything or mess it up with extreme force.
3. last semi important question. does the wifi ribbon cable have anything to do with touch activation?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Reset your iPod by pressing home and power together for 10 seconds, or until the apple logo comes up, and try again
From there, restore your iPod(if you value your jailbreak and it's jailbroken, don't take 5.1 unless it's force fed)
I have a way to do it, but I need to find iOS 5.0.1 and you need to back it up first, it wipes everything and it's 50/50 if it works, but it's worth a try
plug it in normally and back it up first, then put it in DFU mode
First, press and hold the power and home button together with the cable plugged into the iPod into your computer
After it resets, let go of the power button, it should be in DFU mode
go to this website and download for your iPod touch
http://www.ijailbreak.com/ipad/download-...
save this file on your desktop or Downloads folder
on a PC, hold control down and press restore, and find your iOS you want to load onto the iPod
on a Mac, it's the option key that needs to be pressed
Take it apart and reseat the connector(s) to the digitizer, if that is no help, get the digitizer replaced, it's defective
answer to question 1, something is off inside, look everything over again and fix it
to answer question 2, if you need excessive force, something is off
question 3-no, but do be careful, it breaks easily if you aren't careful with it
Score 2
Comments:
hey nick thanks but what do i do if the lcd cable won't connect to the iPod touch because I've been trying to fix for too long. should i use glue or adhesive to connect it?
by
check the connector on the board for visible damage, and screen seembly that was not there, if there is no damage on the logicboard, the screen connector is bad, screen connector is fine, the logicboard's is damaged, but only if it's always loose no matter what in one spot how much you try
by
a.k.a anything you don't recall seeing before the old digitizer was removed
by
nvm nick its working but how would you suggest i pry it back in without damaging it? full force work around the edges?
by
your info actually helped a lot bro but how do i pry it back in?? the bottom is preyed i feel like in idiot thought it seems so easy after all this hard stuff. OH NOOO dude the camera isn't working. what now?
by
Show 1 more comment
Add a comment
Sounds like you lifted the board up without removing the camera from its well and pulled it loose from the connector and you must reconnect it before the board will fit back in. The digitizer is not connected right if you have no touch screen working.
Add a comment
Add your answer
haboo naimee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,598
