The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
415 Questions View all
Doesn't read discs until about 3 mins after warm-up
I just got an XBOX 360 the other day which has confused me a bit since I have never seen this. The system runs fine other then the reading problem. I have cleaned it out inside and out including the dvd drive.
So, when you first turn on the system, you can insert whatever you want and it won't read it at all. After about 5 mins of being warmed up, it will read everything under the sun without issue. It seems like the laser needs to warm up or something but that kinda defy's the logic of the laser unit.
Any suggestions on the cause of the problem and how to eliminate it without just random replacing or parts until it goes away?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Anything is possible :-) and it is possible that your laser assembly is having power issues. It could be the diode on the laser as well as other components on the assembly. You can replace just the assembly, instructions are on here and the assembly is available from places like this. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Kevin Wells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 801
