1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Question Closed
Compatibility of micro SATA (usata, msata) adapter?
I have a micro SATA SSD with an adapter to normal SATA. I pulled this from one of my other MAC's wanting to speed up my mini but once installed it's invisible....
Anybody got a clue why?
-Stock 80gb drive works
-SSD not seen by disc installation setup
-SSD not seen by OSX when booted from USB drive
-SSD IS seen when put in a SATA docking station connected through USB
-SSD model: MMBRE64GTDXP-MVBD1
-uSATA adapter model: http://eu.startech.com/Cables/Drive/Micr...
Thanks for any suggestions!!
2 Comments
Does the drive have four jumper pins on it?
by
Nope, no pins... just the sata data/power ports. Thanks for thinking with me :-)
by
Add a comment
Most Helpful Answer
Your hard drive may have a faster speed than this older MacMini can see. I think yours will see up to 1.5 Gb. Yours may be running at 3 GB. Usually all this requires is to use the jumpers to slow it down but as yours has no jumpers, it may not be able to be used in your machine. I would contact the manufacturer.
Score 1
Add a comment
Nico, did you ever get sorted I have same issue with my macbook pro :(
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,943
